What you're describing is pretty common with Lycomings - it's when the idle circuit cuts out and the main jet takes over. Annoying though it is, there's nothing seriously wrong with the engine.
I don't think I'd be drilling the main jet for this. If, when you're flying (not on the ground) you can lean the mixture and get 100 degrees of EGT increase, you are probably okay with the main jet.
Was the carb rebuilt when the engine was done?
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
