I just had to put out a quick write-up about RoadRunner Transportation. These guys are great! I just had my wings delivered this morning. Even though I was ready to drill in castor wheels, like other builders have mentioned, the driver said not to worry about it. He had the big crate on a hand truck, and the spar/longeron box had two pairs of moving sling straps. A little bit of help (surprisingly little) from my father and I, and they were both maneuvered onto the liftgate. Delivery straight into my garage, and I had to practically shove a $20 into the driver's hand for having everything so perfectly orchestrated. Wanted to give him $40, but I'd have to get the staple gun out to get the driver to take it then.
And I won't even mention the discount from the bill that Van's has set up through RoadRunner. Don't know if it's on par with Estes, ABF, or the others. But it was *massive*. Practically cross-country from the factory to Cincinnati for a few hundred bucks. And their terminal, come to find out, is just around the corner from Butler County Airport, where I'll eventually end up.
Thanks a bunch to RoadRunner!!!
