Old 08-06-2012, 10:08 AM
Joe Joe is offline
Default 4-into-1 exhaust for an RV-8A
Has anyone successfully installed a 4-into-1 exhaust on an RV-8A? A call to Larry Vetterman convinced me it's impossible due to the location of the nosegear at the cowl exit but another exhaust supplier (Aircraft Exhaust, Inc.) asserts it can be done by prototyping with PVC tubing. If that's the case, I'd like to hear from someone who has been successful. Better yet, I'd like to buy one ready to bolt on.
Joe
Joe Dubner
RV-8A
Independence, OR
Old 08-07-2012, 05:40 PM
jmates jmates is offline
Default re: 8A 4:1 exhaust
Hi Joe,
I posted pretty much the same question about a year ago. My post was met by absolute silence. Like you, I'd sure be interested in an answer to your question. I thought I'd at least break the silence some...
John
8A builder (Portland)
Old 08-07-2012, 06:25 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
The nosegear on an -8A is definitely going to require some creative routing to get a 4-into-1 exhaust to fit. The other exhaust guys might be onto something if you can get a PVC tubing prototype made to fit. It'll be an iterative, trial and error process though. Have you considered a 4-pipe straight system? They sound and run pretty darned good.
Neal Howard
Airplaneless once again...
Old 08-07-2012, 06:52 PM
Berchmans Berchmans is offline
Default 4 to 1
It has been my experience that if you need to add bends and turns to go around something like the nose gear leg you will simply increase back pressure. Likely it's not practical and would mechanically be a step backward from the desired outcome.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
Old 08-07-2012, 07:50 PM
DanH's Avatar
DanH DanH is offline
I'd suggest the nosegear clan carefully study the exhaust arrangement on the fastest Lancairs.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-07-2012, 07:55 PM
pat pat is offline
Location: Midland, Michigan 3BS Hanger 4B and sometimes at home
I doubt anyone here will say it can't be done but I tried to no avail and finally had Larry build me a 4 pipe system. To compare apples to apples I also had to work around a cold air sump which sits about 2 inches lowere than a std sump.
Patrick Howe
Citabria 7KCAB - sold
RV8A FB - flying
Old 08-08-2012, 06:32 AM
Joe Joe is offline
Originally Posted by pat View Post
I doubt anyone here will say it can't be done but ...
I agree -- no one will say it can't be done but no one can cite an example of it.
That brings up the question: how does one register an RV-8A in Europe where many countries have stringent noise regulations? I can't imagine the standard crossover system complies or the 4-pipe system offers any improvement in the noise category?
Joe
Joe Dubner
RV-8A
Independence, OR
Old 08-08-2012, 12:43 PM
zav6a zav6a is offline
Default a' la Lancair
Thinking about it Dan. Lots of room out there to run exhausts out and make a nice, smooth, unobstructed airflow transition out of the cowl. I had presumed there is some unforseen problem with it given, to my knowledge, no one has done it.
____________
Duane Zavadil
RV-6a, IO-320
Old 08-08-2012, 01:34 PM
DanH's Avatar
http://aerochia.com/parts_images/NA_2_lrg.jpg
http://aerochia.com/parts_images/NA_5_lrg.jpg
http://aerochia.com/parts_images/NA_12_lrg.jpg
http://aerochia.com/parts_images/NA_9_lrg.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-08-2012, 01:49 PM
Default Lancair
Thanks Dan. I should have said I have not seen anybody do it on a Vans!
____________
Duane Zavadil
RV-6a, IO-320
