08-06-2012, 06:31 AM
The price of ELTs
My whip antenna for my Artex 406 mhz ELT (mounted on the top skin) broke off somewhere last night while finishing the last few hours of my Phase I testing, so I went online today to see how much a new antenna would cost.
That's when I saw this.
The ELT with the rod antenna is about $2000. The same ELT with a whip antenna is about $950.
Why would the price double depending on the antenna?
08-06-2012, 06:43 AM
It's not quite that different. The whip model is $939 and the rod model is $1489. Even though, $500 for an ELT antenna is a bit steep. As a point of reference, the Ameri-King rod antenna alone is $488 so that pricing is in-line.
Whip: http://www.aircraftspruce.com/catalo...es/1103492.php
Rod: http://www.aircraftspruce.com/catalo...es/1103493.php
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
08-06-2012, 06:53 AM
Ah, on the page I found, it was listed at $1995.
So, I'm looking for replacement antenna options, only I have to get up and go work for a living so these $600-$700 antennae are out of the question. I'm not going to spend that kind of money for a piece of equipment whose reliability is questionable to begin with.
Anyone got a source? Otherwise, I'll just duct tape a coat hangar on there.
08-06-2012, 06:59 AM
I don't know if they are interchangable, but the Kannad whip antenna is only $129 and the ACK is only $99. The replacement antenna for your ELT might not be all that bad. The whip antennas seem to be resonably priced. I don't see yours on ACS, but you may just want to call the manufacturer.
Kannad: http://www.aircraftspruce.com/catalo...ges/ant200.php
ACK: http://www.aircraftspruce.com/catalo...antennaE04.php
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
08-06-2012, 09:01 AM
I have an Airtex antenna
Long story, but I do have a new Artex 406 antenna. PN 110-773. If your interested PM me. Or call at 623-570-thirteen twenty.
These guys seem to think the antenna is worth more than the electronics. Go figure... It might be worth a call to them first - maybe they will send you a new one.
Roger
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
08-06-2012, 11:27 AM
Aircraft Spruce wants $218.95 for another whip. That's criminal. A piece of stinking wire.
08-06-2012, 11:33 AM
Forum Peruser
I agree with you, Bob. If you can determine the required length, you should be able to make your own. I mean, after all, you built the airplane.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
08-06-2012, 11:47 AM
I've still got the base and about 4 inches of the wire. I'm not much of an engineer but seems like it would be possible to do something with that.
08-06-2012, 12:17 PM
Hi Bob,
We'll see if we can do something better for you, but that's what you get for mounting it on the outside of the airplane (put it inside next time and you'll gain speed, and have one less hole in the plane)!
Stein
08-06-2012, 12:26 PM
The thing is: I like the look of an external antenna array. Yeah, I know, I'm an outlier.
