Old 08-05-2012, 12:48 PM
John Collier John Collier is offline
Default Aircraft Storage (6-9 months)
I'm going oversees for a few months and my RV will be flown very little....if at all. What things should I consider doing before leaving town? I'm in Tucson, AZ so low humidity. I could probably have the battery charged / engine started once or twice at a minimum.
Any suggestions much appreciated.
-JC
John Collier
RV8
N774BC
Niceville, FL
Old 08-05-2012, 01:16 PM
Mel's Avatar
Mel Mel is offline
Default A few months is not a big deal.....
May not be an option for you, but the very best thing would be for someone to fly it once a week.
Otherwise, fog the engine during shutdown, place a sign on the prop that says "Do Not Turn", and leave it.
Do not start the engine unless the airplane will be flown. Running the engine on the ground is NOT good!
It just creates moisture within the engine. See Lycoming Service Letter L180B.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-05-2012, 06:07 PM
Gash's Avatar
Gash Gash is offline
What is the proper way to fog the engine?
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A
Yak 50
=VAF= donor 2021
Old 08-05-2012, 07:49 PM
Default Fogging the cylinders?
I believe it is when you remove the top spark plug and spray the cylinder with oil. I've read that most use a bug sprayer and thin the oil as required with kerosene. Mel...anyone?
John Collier
RV8
N774BC
Niceville, FL
Old 08-05-2012, 07:55 PM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Originally Posted by John Collier View Post
I'm going oversees for a few months and my RV will be flown very littleC
Beercan,
I'm in the same boat and so used the tanis system here:
http://www.aircraftspruce.com/catalo...ges/tanis1.php
Like Mel said, the best thing to do is have someone fly it once a week. If that is not possible, pickle it. Many, many folks here on VAF have made it clear that simply starting the engine once every so often will do more bad than good. Fly or pickle is my advice.
Check your PM.
RV-7 Flying since 2004
1,200 hrs+
Old 08-05-2012, 10:13 PM
Gash's Avatar
I'm curious about the Tanis system for engine pickling that you linked to. Is there a proper way to "un-pickle" the engine when you're ready to fly again, or do you just go out and fly it without doing anything special? I get to go on the occasional military deployment to various garden spots around the world, and I will need to come up with a proper engine storage procedure during extended trips away.
RV-14A
Yak 50
=VAF= donor 2021
Old 08-06-2012, 07:16 AM
Walt's Avatar
Walt Walt is offline
Good info from Shell:
Engine Preservation
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 08-06-2012, 07:27 AM
Ironflight's Avatar
VAF Moderator / Line Boy
So here's a question for the old-time mechanics out there....I happen to have half a case of fogging oil (spray cans) from my jet skiing days. You fogged the two-strokes every time you cleaned them up, especially after riding in salt water.
How would this stuff work in the Lycomings?
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-06-2012, 12:28 PM
Mel's Avatar
Mel Mel is offline
Default Fogging Oil!
I've used it on several Lycomings with no problems.
The innards of my Jabiru 3300A is covered with it right now.
Old 08-06-2012, 01:28 PM
AZtailwind's Avatar
AZtailwind AZtailwind is offline
I have seen this also. Take the bottom plugs out and spray up if you don't have a fine mist sprayer. That will drip down to where the top rings contact the wall. Also include the plug dehydrators and you should get away with this here in Arizona. But it does not save that Lyc. cam for long term storage. I think the cam is just as subject to rust than the Cyl,s. I'm with Mel, fly it for an hour a month...
Brad Ransom
http://www.westcoastravens.com
RV-6A 180HP-acquired
RV-4 180HP-acquired
