I am wiring my mag switches according to Aeroelectrics Z-11 diagram. I dont know if I understand the diagram symbology in regards to hooking up the tabs identified as tab #2 and #3. Here are 2 pictures of the switch and how diagram Z-11 says to wire it.
Here are 2 pictures of how I wired the switch
I stripped the shielding back off the wire and ran it to switch #3 (top left in picture)
2 questions:
1) Did I wire that correctly?
2) Is there any way to check my pigtail connection/crimp to make sure I am making good ground connections prior to hooking it up to the actual magnetos
