Old 08-01-2012, 12:29 PM
Daniel S. Daniel S. is offline
Default Leading edge lighting kits
Does anyone know of a good leading edge landing light kit or plans? I don't want all of the **** that comes with duckworks / whelen kitsas Im using an LED landing lights.
DANIEL S.
RV7-A (528KS)
-Empannage Done.
-Electrical System Planning / Schematic Done.
-Wing Kit Delivered 09/13/12.
-Wings 95% Done Flaps & Electrical to go.
-Have got to order the fuse soon!!!!.
[/font]http://www.mykitlog.com/dschoning/
"This is a first-time event, and we're looking forward to it"... Chuck Yeager
Old 08-01-2012, 12:41 PM
sbalmos's Avatar
sbalmos sbalmos is offline
I just bought a pair of AeroLEDs 1600s, and plan on getting a pair of the Duckworks blank leading edge mounting kits. That seems to be a popular combination for RV leading edge lights.
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 08-01-2012, 12:43 PM
Would you happen to have a link to the blank mounts? I cant find them anywhere.
DANIEL S.
RV7-A (528KS)
-Empannage Done.
Old 08-01-2012, 12:48 PM
sbalmos's Avatar
http://duckworksav.com/InstallKits.html
Old 08-01-2012, 01:17 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I used Duckworks install kit, and my own homebrew HID lights.
Good choice.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-01-2012, 01:18 PM
Perfect... Thank you! That is exactly what I was looking for!!!!! Guess I didn't look hard enough.
DANIEL S.
RV7-A (528KS)
-Empannage Done.
Old 08-01-2012, 01:38 PM
rapid_ascent rapid_ascent is offline
I bought the duckworks mounting kit and reflectors. Then I bought a separate HID kit. The mounting kit is still expensive, but it looks good. The HID kit was about $50.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 08-01-2012, 07:57 PM
n82rb's Avatar
n82rb n82rb is offline
i made mine in a couple of hours with 50 cents worth of plexi and some bits from the scrap bin. I heated the plexi up with a electric space heater and then wrapped it around the leading edge. I made a z channel for the bottom to fit into and riveted it to the skin. i used three screws in the top with a strip with nutplates on the bottom side of the plexi. i used two pieces of .063 angle to mount the plate for the light on. on the bottom I used a piece of hinge and on the top two long screws with springs to use as adjusters. mounted a reflector from a driving light from pep boys airomotive and done. less than 20 bucks including the driving light that gave up its life for the reflector.
bob burns
Old 08-02-2012, 07:46 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default HID Home brew?
Hi Mike, any more info on the home brew kit? Photo? May want to do the same.
Thanks, al
Al Girard, Newport, RI
N339AG
RV-9
