Old 07-31-2012, 09:38 PM
N546RV's Avatar
N546RV N546RV is offline
Default Blind rivets in tight spaces
Now that I'm back home from losing my OSH virginity, it's back to work on the tail. Tonight I got to the point of blind riveting HS-707 an -708 to the forward spar, except...yeah, there's nowhere near enough room to get my cheapo Lowe's rivet puller in there. I might be able to do it if I bend the rib and angle the puller, but after experimenting with angling the puller head while pulling a rivet in some scrap, I wasn't too happy with the results; the head didn't even sit flush with the material.
The one I have looks like this:
I was thinking of swinging by Harbor Freight Aviation Supply after work tomorrow and looking at one of these:
What are you guys using to pull rivets in tighter locations like this? Am I overthinking this?
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 07-31-2012, 09:50 PM
jlfernan's Avatar
jlfernan jlfernan is offline
Do like they do on the '12, make a wedge from aluminum with a hole in the center to make it possible to pull the rivet.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 08-01-2012, 06:09 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default Modified rivet puller
Take a look at this EAA video:
http://www.eaavideo.org/video.aspx?v=60653678001
I bought and modified a rivet puller specifically for this use, and it works great. The tool looks a little banged up, but the results are spot-on.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 08-01-2012, 06:42 AM
rgmwa rgmwa is offline
This one is good for tight spaces. Also bending the rivet shank about 15 deg, and using the AEX wedges as per the RV-12 plans works well.
http://www.erivet.com/storefront_pro...estTimeout=120
rgmwa
RV-12LR 912ULS
120346
Old 08-01-2012, 06:59 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I used one like this quite a bit, it's narrow...
http://www.redhillgeneralstore.com/h...Rivet-Tool.htm
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
