Old 07-31-2012, 07:32 PM
blbills blbills is offline
Default RV Capacitive Fuel Sensors
Hi all!
This is my first post on the forums. Recently acquired a very nice RV-4 and I'm absolutely loving it.
Want to upgrade from the D100 to a Skyview over the winter and was hoping for some suggestions on reading the fuel level.
I imagine that capacitive fuel sensors are the way to go but wondering how much of a pain it's going to be to install them when the airplane is already built. Does anyone have any suggestions?
Brian
Old 07-31-2012, 11:10 PM
BruceP BruceP is offline
Default I wouldn't do it...
It would be very difficult to retrofit capacitive sensors as they are two plates that mount next to the ribs in the tanks. You would have to open up the entire aft baffle to get access. I don't think it would be worth the effort and having to re-seal the tanks would be painful. If your regular float type are working there isn't a compelling reason to change. Even if they aren't working, replacing the float type would be much easier.
Welcome to the VAF community! You will find very knowledgable, helpful folks here(Most with much more knowledge than me!)
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 08/20
Old 08-01-2012, 08:44 PM
Bruce,
Thanks for the reply! Yes, my standard float type sensors aren't worth beans. I was really hoping for an accurate method of reading the fuel level on the skyview.
Any other suggestions?
Old 08-01-2012, 08:51 PM
Brantel's Avatar
Brantel Brantel is offline
There are some probe type capacitive sensors that may be much easier to install on finished tanks.
http://www.vansairforce.com/communit...ad.php?t=87783
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-04-2012, 11:01 AM
Has anyone attempted to install capacitive sensors on a finished RV? Am I crazy for even thinking about it?
Old 08-04-2012, 05:24 PM
brian's Avatar
brian brian is offline
One thing to keep in mind about capacitive fuel sensors is that they are very dependent on the type of fuel. If all you ever use is 100LL, not an issue. For people who might sometimes use mogas and sometimes 100LL, capacitive sensors are of little use, as the readings will vary greatly.
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
