Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 07-28-2012, 07:38 AM
sbalmos's Avatar
sbalmos sbalmos is offline
Default Continental's new TD- diesel series
Granted, the first engine (TD-200) is too powerful for me, in the 200-250hp range. But that TD-220 they say they're going to develop and have around in the 2016 range has me drooling and reconsidering my long-term options as I build. Originally I was going to find a run-out O-320 core and rebuild it for full mogas, dual P-mags and everything. Now when the time comes (2014-15 range), I may just find a mid-life O-320 or even a cheap high-time one to get the plane flying, and just swap for the TD-220 when they're released.
Anyone else hoping we might actually finally have a viable piston diesel coming off the production line here?
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 07-28-2012, 07:52 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
More info and links:
http://www.aopa.org/oshkosh/2012/new...f-diesels.html
http://www.avweb.com/news/airventure..._207047-1.html
http://www.rtbot.net/Continental_TD-300
RV-7 Flying since 2004
1,100 hrs+
Old 07-29-2012, 10:26 AM
cujet cujet is offline
While the promise of better fuel economy and performance are there. Consider the additional costs (the SMA 230HP eng is, I think, around $100K) . And, of course we should consider the additional weight of the fuel and the heavier diesel engine. I think there is a good reason to stick with conventional aircraft engines and Avgas.
Jet A is significantly heavier than Avgas, and contains more energy per gallon.
But, by weight, Avgas and Jet-A's energy content are well matched. As aircraft operators, we fly by weight, even if we purchase by gallon.
It's not unusual for today's experimental Lyc/Cont to achieve "very near diesel" levels of efficiency. And, I'd suggest that the lightweight, reliable, powerful conventional aircraft engine is better suited for sport flying.
I'm not certain an aircraft diesel would have any "return on investment", especially early on in the development of such engines.
Old 07-29-2012, 06:06 PM
flywithme623's Avatar
flywithme623 flywithme623 is offline
Default My dream Engine
Yes, I do dream to have one of those nice smooth running diesels.
I get to fly a DA42 with Thielert diesel engines every now and again and love it.
Though my default is the the IO360 180hp, but I'm still dreaming
Michael Zimmermann
RV-8 Sold
Happy people don't necessarily have the best of everything,
But they make the best of everything they have.
German immigrant who's living the American dream!
Old 07-29-2012, 06:48 PM
flyvans.com flyvans.com is offline
had a very interesting discussion with one of their test engineers today at osh.
definitely a development to follow closely, overall a very solid and thoroughly thought through concept.
one of the downsides for RV/experimentals is that the focus is mainly on certification / initially targeting a different/heavier, more powerful segment. also, because of certification, the approach is rather conservative, not necessarily pushing the limits of what could be squeezed out. then again, having a reliable jet-a1 option is worth just as much.
one important thing that i took away from the conversation is that each of the three engine models is significantly different with all the lessons learned on the previous development being included in the next and not just e.g. adding/removing cylinders. so look at the model that fits the RV's in the 2016 timeframe as the third generation which can be an advantage as well.
i certainly wish them luck and it's not just vaporware, the thing is flying in a 182 and by all indications flies very well...
regards,
bernie
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
Old 07-30-2012, 08:25 AM
kgood kgood is offline
Default I'm a diesel fan...
I guess it's time for me to weigh in...
I've been flying my turbo diesel (WAM) RV9 for almost 4 years and pushing 400 hours. I can't say enough good about it. It's a joy to fly. I didn't realize how good it was until I recently started flying an avgas plane again. It has taken me awhile to get used to the complication and expense.
With the diesel, there's no priming, boost pump, mags, mixture, carb heat, flooding, plug fowling, egt to worry about or mess with. Just get in, start up, cycle the prop, and fly. Plus, the fuel is much safer in the event of an accident.
You can do math any way you want, but in the real world, the diesel is much more efficient, especially when you consider the entire flight profile. An avgas engine running LOP may start to approach diesel efficiency at cruise, but never for the entire flight.
I'm sure I'll get burned for this, but I still believe diesel (Jet A) is the future. Just look at all of the investment dollars being poured into it's development. Someday someone will get it right (I don't believe the "right" engine is available yet) and people will begin to understand all of the advantages.
Kurt
RV9 / WAM 120 diesel, 380 hours.
Old 07-30-2012, 02:19 PM
Default Love JET-A
Kurt, I think you are totally right. I hope when it comes to my install I can get me a diesel engine.
For me its the price right now that is holding me back.
Also since I am planning to install EFIS I am looking into an engine manufacturer that has software that will talk to that EFIS.
I would be very interested what system upgrades you had to make, other then larger fuel filler cabs. (Fuel lines, Gaskets, Fuel pump etc.)
Will that engine fit on a -8? It looks real big on there website.
Michael Zimmermann
RV-8 Sold
Old 07-30-2012, 06:54 PM
Default Love JetA
Michael,
The WAM is actually quite small. It will fit into any Van's, except maybe the '12. And it is very light, weighing less than the comparable Lycoming. The problem is that it doesn't make enough power for an RV8. When they finally introduce the 140 hp version, it may be enough. I believe that with 140 hp the performance will approach that of an O-320. This is based on testing we did between my 120 hp turbodiesel and Van's O-320-powered RV9A.
I did not modify my fuel caps, although I should have. There have been a few instances (in Mexico mostly) where I've had to use a funnel that I carry on board. The only modification I had to make to the airframe is the 1/4" fuel return lines and Andair fuel selector valve.
Obviously, the FWF installation itself is basically custom, requiring a special mount, provided by WAM, cooling system and cowling.
Kurt
Old 07-30-2012, 07:06 PM
Thank you Kurt
Good info, maybe by the time I get to install one there is some more upgrades. I just love the way those diesels work. Like I already mentioned above, the Diamonds diesel are awesome. Start up at any temp, smooth and easy maintenance. I'm so looking forward to more development. Diesels are the future, you are right about that.
Take care
Michael Zimmermann
RV-8 Sold
Old 08-13-2012, 02:16 PM
johnjohnhere johnjohnhere is offline
Default engine choice
Why are the Diesel motors that are used by Diamond not more widely used? Is there a issue with them? I ask because I am totally unaware ! Who makes the engines Diamond uses on the diesel?
RV-8 tail sold; RV-14 Idea being looked into.
