Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 07-27-2012, 06:29 PM
hlangebro's Avatar
hlangebro hlangebro is offline
Default Whirlwind GA200L and James shorty cowl issue
Got the ground adjustable prop today.
I have a question though: I have the Sam James shorty cowl on my RV-7A. It seems like I dont need the spacer...?
The cowl is too short when the spacer is in place. If I remove the spacer, it is pretty tight, but probably workable (maybe).
Does anyone have any experience with this? Should I keep the spacer and extend the center/hub part of the cowling, or extend the rear of the cowling, or should I skip the spacer???
H?kan Langebro
San Diego, CA
RV-7A, slider
Lycoming O-320 D1A, 160hp C/S
First flight 6-11-13
Re-engineering a Lancair 320..!
http://www.youtube.com/watch?v=AJuQ68tccTQ
http://www.mykitlog.com/hlangebro/
