re: wing bolts
Mike,
I put washers under both the bolt head and the nut. And yes it is a b**** to get those bottom bolts in, nuts started and then torqued but doable. Good luck. A big bottle of Motrin ready for when you get through. I used the crazy glue trick to glue the washer to the nut to keep from going totally insane every time I dropped the nut. And then the next week repeated the whole ordeal on a RV-9A. take care. Tim
Tim Pethel
Coffee Springs, Al
RV-8A SB Wings Done
Fuse done
Airworthiness cert issued.
Flying as of 08/12/12
Out of Phase 1
200 hours
