Old 07-25-2012, 06:32 PM
jim miller jim miller is offline
Default Fuel Pump Inlet/outlet
I just installed my Lycoming fuel pump with cooling shroud and now not
sure which is the pressure outlet to carb. When looking from behind the
engine one port is on left, the small drain port in middle, another large
port on right. Which one is the fuel out to carb?
Jim Miller
Old 07-25-2012, 06:40 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
On my YIO-540, the port on the left is the pressure port and the right port is the inlet port.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-28-2012, 10:02 AM
Charlie
Thanks. After reading your post I was able to make out some markings on
the bottom of the pump to confirm mine is the same as yours.
Jim Miller
