07-25-2012, 03:23 PM
Squeezing Ailerons
Everyone talks about 'squeezing' an aileron but do not say how you do it?
Do you use your fingers? Do you use 2 pieces of flat wood and use vise grips set to a fixed pressure? Do you do 1" at a time, 3" or 6"?
How do you turn your leg fairing to raise a 'heavy' wing? Will the drag penalty be worth it?
Questions, Questions, Questions?
07-25-2012, 04:50 PM
The way I squeezed the aileron is to use two paint sticks in a set of seamer vicegrips (the ones with the large flat plates in the jaws) Take it easy, it doesn't take much,, do a little then fly. Also fly with the aircraft properly weighted, expect left wing heavy with only the pilot in there.
RV-6 (AircraftWraps Sept 15, 14)
07-25-2012, 06:04 PM
Van says LAST!
There are 20 things to rig before that. Everything from ailerons being mis-rigged to pants being off. Remember you can't un-squeeze it...
Bob
RV-10 QB Here 8-25-19
RV-7
My brain shows a remarkable capacity to not willingly accept information that it considered useless.
07-26-2012, 05:07 AM
Errrr maybe.
You can kinda, sorta unsqueeze them Bob. You place a 2 X 4 or similar, vertically against the trailing edge and hit it with a hammer...carefully.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
07-26-2012, 05:34 AM
Don't use fingers, it will leave peaks and valleys in the trailing edge.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
07-26-2012, 05:45 AM
Be very cautious as it take very little force and undoing it will be harder.
For a nice can clean squeeze, take two long angle aluminum on either side of the trailing edge with a bunch of C-clamp evenly spaced. This gives you a good control to squeeze little at the time. As others mentioned do a little and fly, repeat till desired evenness has achived.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
07-26-2012, 05:46 AM
The paint sticks and seaming pliers is about the best method.
Again, be careful. A little goes a long way. If you can see that you've done anything, you may have done too much.
Just do a little and go fly. It's much easier to do multiple times than to "undo".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
07-26-2012, 06:19 AM
squeezing
I recently did it (after exhausting other methods) and everyone is right, a little at a time. Do about 6-8" at a time. I squeezed a three foot section first and it drastically gave me a heavy wing in the opposite direction which I could not bring out even with a very large wedge. I reversed it by the 2x4 / hammer method and now its just right. Like everyone said, BE VERY CAREFUL, go slow!!
Jim
RV-6
07-26-2012, 07:44 AM
Just remember, if you are a side by side, solo, with a balanced fuel load, you will have a heavy left wing. Balance your fuel load between the tanks, place an equal wieght passenger or ballast in the seat next to you, and then see.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
08-10-2012, 07:16 AM
Just so I understand
I bought my 6 used, and with equal fuel, I have the right wing dropping on me with a passenger of equal weight. With a passenger, I have to turn my aileron trim to the left. So for now assuming everything else is lined up, this is indicating a right heavy wing, correct?
If I do this, I would squeeze the opposite aileron on the left side?
