Old 07-24-2012, 08:29 PM
kens_cockpit's Avatar
kens_cockpit kens_cockpit is offline
Default Elevator attachment - How do I get the nuts on?
I'm attaching the elevators to the horizontal stab. There just isn't enough room to put my fingers in to attach the nut. There is enough room to hold the nut with some long nose pliers but not enough room to turn the bolt with a spanner. Clearly I'm a pretty poor problem solver but I haven't come up with a way of getting the nut on in the small space available. I'm sure there is wisdom already on these forums but I haven't found it. Neither have I found it in the RVator or Bingelis books. I'm stumped. What is the trick here?
Ken Stanton
RV8 QB
Wing attach
Building a plane again after building family
We inhabit a mystery. We should not pretend to know too much.
-Eugene Peterson
Old 07-24-2012, 08:34 PM
Archangel Archangel is offline
Have you tried the piece of tape on the end of a stick yet? The scotch tape will hold in place enough to get it started. At least I've seen that trick on the EAA a few times.
Old 07-24-2012, 08:38 PM
rv9aviator rv9aviator is offline
Forceps work great for that
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
donoltman donoltman is offline
Default nut install
I'm sure there are a number of ways. I used said needle nose pliers to put into place, reached down with my pinkie finger to hold pressure on the end of the nut and then used a nose picker to spin the nut on. Good luck.
Don
Old 07-24-2012, 08:48 PM
DarylT's Avatar
DarylT DarylT is offline
Default These from CLeaveland
http://www.cleavelandtool.com/prodinfo.asp?number=WWR4
These washer wrenches make this job a 2 minute task. There are several places these help.
Get em!!!
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 07-24-2012, 10:02 PM
Low Pass's Avatar
Low Pass Low Pass is online now
Hemostats to start, open end wrenches to finish... You'll find that this project will require some outside the box thinking. Double sided tape on a stick, safety wire looped around the nut, etc. Custom made/modified tools are required in quite a few steps.
Just wait until you get to the gear tower!!
Old 07-24-2012, 10:08 PM
RV9A Bill RV9A Bill is offline
Default Small hands
A wife with small hands is a help in this situation and others like it.
RV9A Bill
Old 07-24-2012, 11:11 PM
jimgreen jimgreen is offline
Sometimes a nut driver can be used where a socket wrench won't work to start a nut. The nut drivers are normally quite shallow so the nut doesn't get swallowed up like it would with a socket.
Like they said, lots of different ways to try.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 07-25-2012, 02:36 AM
WAM120RV WAM120RV is offline
Default Finger trouble
I have just done this on my 4 ( see the blog).
The first thing you require is lots of patience. I used just enough double sided tape to hold the nut on my finger to line it up then slowly span them on with the other index finger.
Dont forget to do the correct tightening sequence. Tighten/torque the nuts on the outer two bearings on each elevator first, then check if a spacer is required each side of the centre carry through bearing. Make spacers as appropriate..... could be washers... tube... then put in the centre bolt.
You will only be able to tighten one flat at a time so its a slow process, but don't try to rush you will juts mess up your paintwork.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 07-25-2012, 09:17 AM
airguy's Avatar
airguy airguy is offline
Wait till you hang the rudder - it's even more fun!
