07-23-2012, 06:56 PM
0-320 with 160HP upgrade?
Hello. I've recently ran onto a 6 with an o-320 e2d that was upgraded with larger pistons and now 160HP. Just curious as what this does to the existing parts within the engine, as in, how well do they handle the additional torques and stresses? I'm green with this, as to why I ask. Last thing I want, is to buy someone elses problems. Since major, the eng has 1150 and it's turning a m/t comp. fixed prop. Thx for any info/advice. DM
07-23-2012, 07:17 PM
Lycoming makes pretty much the exact 160 hp 320 still. The TBO is still 2000.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
07-23-2012, 07:18 PM
UPGRADE
The E series had plain steel cylinders vs Nitride on factory 160 hp. The certified upgrades to 160 hp require either Nitride, chrome or nickel cylinders. Lots of 160 upgrades on EAB with plain steel cylinders. The front main bearing configuration doesn't matter unless you are planning to change to a constant speed prop. Mosty of the E series have 0 235 front main which will not support a constant speed. A few have the two piece front main which will support the constant speed if the engine is set up to accomodate a governor.
07-23-2012, 07:37 PM
ok
So it sound pretty much a normal procedure, providing a worthy shop did the repair and all is documented. I think the compressions are all at mid 70's and not using much oil. It is regulary run. I think the secret to longevity is "run the **** outta them"
07-23-2012, 08:42 PM
Going to 160 hp is accomplished by installing 8.5:1 pistons.
I installed 9.5:1 pistons in my E3D. I have over 800 hrs since overhaul and it still runs great. I've had absolutely no problems.
The E3D is basically the same engine as the E2D except that some E2Ds didn't have the fuel pump.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
07-24-2012, 03:17 AM
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
160 hp
Changing to higher comp 160hp pistons is the standard and usually done on a rebuild of most O-320 150 hp engines.
The Negitive of higher comp pistons (9.5:1/10.5:1) is that you then will be limited from using Mogas. You will need to use 100LL avgas.
The positive: The 160 hp configuration will actually run more efficiently. do it.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Reason: Clarification
07-24-2012, 04:26 AM
Originally Posted by NickAir
Changing to higher comp 160 hp pistons is the standard and usually done on a rebuild of most O-320 150 hp engines.
The negitive is that you then will be limited from using Mogas. You will need to use 100LL avgas.
I have found this to be not true.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
07-24-2012, 04:45 AM
Agree. Several of the RV's at my home field with 8.5:1 compression engines (0-320's and 0-360's) use mogas.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
07-24-2012, 11:57 AM
Hi comp pistons vs Mogas
I have been advised by professionals, the following:
High comp pistons in a O-320/O-360 (9.5:1 or 10:5:1) not recommended for low octane Mogas.
(8.5:1 is ok for Mogas) I did this for years and still do with good results.
Tailwinds...
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
Sparrowhawk, sold
07-24-2012, 01:14 PM
Gudgeon pins
Have done this with mine...... make sure it has the thick walled gudgeon pins (wrist pins).
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
