Ron,
I just got my wing kit and was looking at the wingtips yesterday. They are pretty flimsy - they look like they would flex and flutter in the wind. I have been thinking about how to make them more stable and considered expanding foam. Im still not sure what I will do, but the plan forming in my head is to build the wing, fit the tip with clecos, then check the fit. If needed, I will build a form or some sort and fill the tips with foam so they will not flex. If there is a better way, Im all ears. I will have to keep this in my head to try and come up with an easier way. I will be interested in how you plan to fix the issue. Maybe the new gray tips are different than the white ones?
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
