Old 07-30-2012, 02:56 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by BHunt View Post
That engine has a 10.5:1 compression ratio and is cleared for 91 UL. How is the 390 not approved for mogas with a 8.7:1?
8.9:1 per the TCDS. Are they "approved" per the same standard?
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-30-2012, 03:10 PM
BHunt BHunt is offline
After further reading, only the lower compression (8.7:1) IO-408 is approved for mogas.
Old 07-31-2012, 07:57 AM
rvnor rvnor is offline
Default MOGAS
Jupp, the 408 is approved for MOGAS with lower compression, 218 HP
And the 390 will also run on MOGAS if the compression is lowered, performing around 200HP.
Remeber, this is Experimental, we can make the changes we want.
And BPE or anyone....will probably offer 390 for MOGAS if we, the customers, want it
OlaM
Old 07-31-2012, 11:17 AM
Bruce's Avatar
Bruce Bruce is offline
Originally Posted by Sig600 View Post
It didn't look like it from the "walk around" video, but does anyone know if the -14 uses a reflexed flap position like the -10 in cruise?
I thought it had Fowler flaps . Reflexable ?????
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 07-31-2012, 11:35 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Not Fowler flaps, just slotted flaps with the hinges shaped like V's under the flap/wing. Very easy to reflex by adjusting the length of the flap pushrods.
Neal Howard
Airplaneless once again...
Old 08-03-2012, 03:40 AM
Ausflyer Ausflyer is offline
Default How much help needed?
I have completed a -12 and really enjoyed the process. Vans technology and paperware were so user-friendly.
I keep seeing reports that the -14 has the same process, and builders can expect a 30% reduction in build time, compared with the -7.
What I have not been able to find in posts to date is just how much of the -14 riveting is solid rivets. And more importantly for me, how much of the solid riveting needs a helper on the bucking bar? I built my -12 on my own. Including flipping the wings. I could set all the rivets without assistance.
Can a -14 be built with minimal help?
Rod
Old 08-03-2012, 06:11 AM
rleffler's Avatar
rleffler rleffler is offline
Rod
Rod,
I'm building a 10, so I can tell you it can be done by yourself. However, there are some tasks that are easier with a partner. Since the 14 uses the 10 wing, riveting the bottom skin is easier if you have a partner to assist. The RV-10 community has a cheat sheet on the order of rivets to do first to make the job easier. I suspect the logic would apply to the 14 as well.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 08-03-2012, 06:58 AM
rocketbob's Avatar
Late to this thread. Saw the -14 at OSH and my overall opinion on it is....
meh.
Just flew a -7 this week and was reminded how much nicer a -6 flies. The -14 will fly like the -10...heavy.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 08-03-2012, 07:07 AM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Default I agree with Bob
I'm building a 10, and I have had less than 5 hours of someone helping me rivet. I am done with 99% of the riveting. Most of that was on the fuselage.
Bill
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 08-03-2012, 06:46 PM
Hi Bill and Bob
Thanks for your encouraging replies. It looks like Vans has single builder as one of their design constraints on the -10. I hope the -14 is the same. They need to point it out more clearly in their promptional releases, if that's the case.
With the 12 vans made a big thing of the lack of jigs and the small collection of tools required. I hope we hear more of that stuff for the -14.
Rod
