Do it
Steve, I'm not that much further along in my 7 build than you, but I did make the rudder bottom removable. For about the same weight and effort as riveting permanently, I can have access to the tail strobe wiring and can replace the fiberglass should it get cracked or damaged with minimal effort. I felt it was worth it
Steve McGirr
RV7 N1991M
First Flight: May 18, 2013
