Garmin SL40 wiring to Garmin 240 plus GRT servo wiring
Garmin Sl40 manual says, ground shielded cables at both ends, ie: radio end and Audio Panel end.
Garmin 240 Audio Panel says to ground shields at 240 end only !
Comments please.
Also;
GRT Servo serial wires are not shielded or twisted. GRT says no problem, Tru Trac and Dynon both twist their serial wires, anyone have any interfernce problems.
I am thinking of replacing the roll servo serial wires with a shielded cable so I can run them through the same conduit as the LED shielded Nav light wires and unshielded Halogen Landing lights wires.
