Old 07-18-2012, 12:42 PM
mvidalr's Avatar
mvidalr mvidalr is offline
Default RV-8 Rudder skin damaged... need advise (help!)
Hello Folks!
I need some advise on a R-801PP rudder skin hole (3/32" dia., .020" sheet alum) which got damaged because I accidentally bent a cleco which was holding in place a R-815 rudder stiffener.
Before deciding whether to order a new skin, I'm thinking about enlarging this hole to 1/8" and use flush rivets AN426AD4-4 instead of AD3-3.5 in both skin and stiffener.
Am I thinking correctly? Is it something to be totally replaced, or just repaired?
Thanks!
Inner part of skin, dimpled and primed:
Here's a close-up with it's respective 3/32" flush rivet...:
Miguel Vidal
EAA #1133587
RV-8 SB Wings in Monterrey, Mexico
N511MV Registered
MyKitLog
Last edited by mvidalr : 07-19-2012 at 09:48 AM. Reason: mistake in original thread title
Old 07-18-2012, 12:49 PM
larrynew's Avatar
larrynew larrynew is offline
Search this site for Oops rivets or NAS 1097AD4 as a possible alternative.
https://www.google.com/#hl=en&output...w=1080&bih=710
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 07-18-2012, 12:56 PM
I would try one of the oops rivets. One size larger body, small head. If you don't have any, Vans and the other suppliers have them or let me know what you want and I will mail you a couple. That would fill is enough to work - judging from the pictures. You could always use a little epoxy or proseal under the stiffener in that location to assure no problems in the future. There may be a spot on the airplane that one rivet could make the difference, but it isn't on that part of the rudder!
There is nothing wrong with using a little filler if you get is messed up a bit. Just make sure it is rated for aluminum and you prepare properly.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 07-18-2012, 03:22 PM
Stalldog Stalldog is offline
Default Wick's Aircraft Supply
I know Wick's has them -- I recently bought several different sizes. Very handy to have around the shop.
Jim
Lenexa, KS
RV-7A
