Old 07-17-2012, 01:31 PM
thomaswimmer thomaswimmer is offline
Default MS20667-5 fork and -4 fork on same cable
Hi,
is there a way to have a cable with a -5 fork on one end and a -4 fork on the other end?
Thomas
RV-9 under construction
Wr. Neustadt, Austria
VAF 2013 PAID
Old 07-17-2012, 07:47 PM
paul mosher
Posts: n/a
Default No
Because a -4 is for a 1/8 cable and a -5 is for a 5/32 cable.
Old 07-18-2012, 02:30 PM
I knew that the -5 and -4 forks are for different cable sizes.
My question was more like this:
I want to connect something that has a 1/4" hole in it to something that has 5/16" hole in it with a load bearing cable.
Opening up the 1/4" hole is not the answer (edge distance).
So can this be done?
Structurally, I only need the 1/4" bolt and 5/32 cable.
Thomas
VAF 2013 PAID
Old 07-18-2012, 02:58 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Can you put a bushing in the larger (5/16) hole??
Then just use the -4 fitting and bolt.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
