Old 07-17-2012, 10:30 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Connecting three wires
What are acceptable practices for connecting three wires? I've seen spade and but splices but that covered connecting two wires. Some of the pin outs for electrical connections show multiple devices connected to a pin in a DB connector or sometimes I need to wire some led lights in parallel. Sho how can I connected three or more leads without adding a bulky terminal strip?
Is it as simple as putting a hook in one wire and then wrapping the other two around that and shrink wrapping? What about DB connectors and need multiple wires connected to a pin?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-17-2012, 11:07 AM
thallock thallock is offline
Acceptable practices are specified in AC 43-13-1B (see 11-167 and beyond).
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 07-17-2012, 11:32 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
If you look on Bob Nuckoll's site, you'll find that the simplest way is to use a butt splice. Put two wires in one end and one wire in the other. Done.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 07-17-2012, 07:02 PM
Gotcha, that is what I was thinking. I saw the 43.13 info and it doesnt really deal with ganged signal wiring or other multi-butt connections.
RV-10
N928MT
Build Project Site
Old 07-18-2012, 02:15 PM
Flying Scotsman Flying Scotsman is offline
Closed-end splices:
That one I'd be interested in, too...I've been able to crimp in two *very small* gauge wires into a single D-sub pin/socket, but beyond that...no dice. I *thought* there was a specific pin or socket which would accept larger gauge (than 18) wire or two somewhat smaller ones, with a different part number, and I could swear I saw it one time, but never was able to find it again.
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 07-18-2012, 02:43 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Exclamation D-sub contacts that allow larger wire sizes.
Positronics Industries sells them.
Allows 18AWG wire to fit standard density d-subs (20-24AWG):
Male - MC6018D [Garmin PN 336-00025-00]
Female - FC6018D [Garmin PN 336-00023-00]
Allows 20AWG wire to fit high density d-subs (22-28AWG):
Male - MC8020D
Female - FC8020D
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 07-18-2012, 11:12 PM
Cool! Thanks...I'll have to bag some of these babies...never know when they'll come in handy!
Thanks!
Steve
Santa Clarita, CA
#8,000
Old 07-18-2012, 11:38 PM
Just have to find them in non-industrial quantities now!
RV-10
N928MT
Build Project Site
Old 07-19-2012, 04:03 AM
rleffler's Avatar
rleffler rleffler is online now
Solder sleeves are your friend.......
You can get them just about anywhere. I've found them at the local big box hardware stores, but they usually carry larger sizes. Both ACS and SteinAir sell them.
http://www.aircraftspruce.com/catalo...s/sumitomo.php
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
