So essentially, load your airplane into the worst possible configuration you can see being possible, fly it there in Phase I (assuming it's still flyable) and that defines your usable Phase II envelope.
Originally Posted by jjconstant
I've also found that the forward part of the envelope (full fuel, including tip tanks and just me at 160lbs) to have unexpected characteristics. I found that is was a bad idea to land full flaps because with the full flaps pitching moment I barely had enough elevator to keep the nose off and the nose came down at a higher speed. Wouldn't have been good on an unimproved strip.
.... and that's exactly why we test the corners in Phase I - good to know these things...
