Trim wire squeezed by servo screw...
Hi guys
I am not quite sure if I routed my wire for the trim servo in the right way.
Actually I wanted to upload a pic but don?t have it online, so I hope my description is sufficient.
I routed the wire from the empenage through the horizontal stab to the left elevator. In the left elevator there is a whole in the spar which is aligned with the all-screw of the servo. That is the reason why the wire is squeezed.
Where did you route your wire through?
Thanks guys!!
Cheers
Sunit
