Old 07-16-2012, 09:55 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Default GoPro Hero2 Underwing Video
I've been VERY happy with the GoPro Hero2 camera. I purchased it shortly before the first flight of the RV-8. I really like setting it up looking over my shoulder and plugging into the audio jack to record my flights. It's nice to show everybody what is going on during my flights and lets me review and critique my flying and especially my landings.
With the Wi-Fi backpack available, I decided to try an external mount below the wing and see what else could be done/seen. Here is what I came up with: http://youtu.be/rYZtt3BUNDo
Also, this is the first time I attempted to edit videos using Windows Movie Maker. As I have nothing to compare it to, I'm happy with the program and the results thus far.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 07-17-2012, 02:39 AM
mike newall's Avatar
mike newall mike newall is offline
I attached mine using the standard sticky clip in mount to the inspection panel and got similar results.
It's a nice perspective and I'm looking forward to upgrading to the GoPro 2 with the remote set up.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 07-17-2012, 03:07 AM
paul330 paul330 is offline
Mike
So the sticky mount copes OK? I have a suction cap and a bar mount - was thinking about using the centre strut. In the long-term, I was thinking of making a mount to fit around the step.
My initial intention is to fit it inside the cockpit to film the instruments during flight testing. I've taken one lot of video on an approach in my "day job" and have to say the results are fantastic. I used Adobe Premier Elements to edit which is a whole lot more sophisticated than Windows Movie Maker
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 07-17-2012, 08:15 AM
Jeff A's Avatar
Wow, I wasn't sure if I wanted to trust the sticky back mount at almost 200mph. I bought the tripod attachment for $9.00 and used a 1/4-20 bolt to attach it. It works pretty well, but I don't like the wavy distortion in some parts of the video....I think the mount was flexing ever so slightly. More experimenting to come....
Jeff Atkinson
Old 07-17-2012, 08:27 AM
kevinh's Avatar
kevinh kevinh is offline
Re: sticky mount
I had great success with drilling and countersinking one of the sticky mounts for a #6 screw + tinnerman washer. This gives secure attachment/movable with no waviness.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 07-17-2012, 02:21 PM
mcattell mcattell is offline
Default GoPro Wi-Fi BacPac & Remote is Great!
I just got one of the GoPro Wi-Fi BacPac & Remote kits for my original GoPro Hero camera. It took a little while to set-up but once I got it working it's great. I tried it out last night during a flight with the camera mounted under the wing. The signal to the camera from the cockpit worked flawless. I could change modes with the remote between photo, timer, video or turn the camera on/off. There is feedback on the remote screen so you know that it's working. I was very impress with it. I think it's well worth the $100 so you're not burning through memory card storage and camera battery by filming the entire flight. Now when you are flying that last 2 hour leg into Oshkosh you can just turn on the camera and video the last 15 minutes.
The GoPro website indicates that the new GoPro 2 will have an App for the iPhone or iPad to view live video when using the Wi-Fi BacPac. That will be really cool. I may have to sell my extra Contour camera and buy a new GoPro 2.
I spent a lot of time trying to get the BacPac to work on my camera the first time. I found out the hard way that there are a couple key things you need to do first. You need to back-up the firmware in the camera and then also to the BacPac and Remote. I had a big issue updating the BacPac but there ended up being a simple fix after finding some hidden troubleshooting tips. You have to use an older USB 2.0 connection to computer (not 3.0) and turn off Windows User Access Control (type UAC at Windows start box). Once I used the correct type of USB port and did that it was simple. Hopefully that'll save you the hours I spent on it.
After the technical issues of getting it working, I'd give the GoPro BacPac & Remote kit a big thumbs up.
Mark - Forest Grove, OR (Homebase KHIO)
Flying RV-9A N962MC
EAA Tech Advisor - Ham AI7MC
Old 07-17-2012, 03:05 PM
Jeff A's Avatar
I had all the same setup headaches, but it works great now. The other issue I've found (and it's mentioned in the backpac user's manual) is that the backpac will "feed off" the main camera battery when it gets low. When I have the camera mounted in the cockpit, I always plug the audio cable in along with the USB cord to keep the battery tip-top.
Jeff Atkinson
Old 07-17-2012, 03:30 PM
Here we go !
http://www.youtube.com/watch?v=9tX1E...3&feature=plcp
http://www.youtube.com/watch?v=q1yIR...2&feature=plcp
Don't forget the gearwheel - go HD !!!!
Donated in 2020
Old 07-21-2012, 01:32 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Mike, I notice some waviness in portions of the first video. Is that the waviness that kevinh has eliminated with his mounting.
Old 07-21-2012, 03:50 PM
Don't know.
I've always assumed the waviness was writing interference onto the card.
I always record at full HD onto a Class 10 card but sometimes get waviness or stuttering.
I believe the GoPro 2 is much better.
I'm getting one soon to replace one that succumbed at 130mph on my buddy's race motorbike on the Isle of Man ..........
The rider was OK, it just fell off and unfortunately, the catch got caught. The casing was in fine condition
I've never seen so many parts before !
Donated in 2020
