  #11
Old 07-17-2012, 07:15 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by DRBuilder View Post
All I needed to do to adjust the weight & balance was to relocate the battery and ELT back beneath the HS. Worked perfectly. You can't foul up the W&B unless you do it intentionally.
See you in OSHKOSH!!!!
That is great news! I know of one S8 that had to put pounds of led in the tail to get the W&B to work out.
So, it sounds like your S7 is a standard -7 with the big engine bolted on, is that correct? If so, I'm even more impressed by how strong these planes are!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-17-2012, 09:48 PM
Sig600 Sig600 is offline
Isnt' your engine mount shorter too in order to shift the weight aft, or am I dreaming this up?
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 07-17-2012, 10:03 PM
RV7AV8R's Avatar
RV7AV8R RV7AV8R is offline
Default The rv14 ?
Maybe the RV14 will be a stretched 7. Maybe we will hear about it next week.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 07-18-2012, 04:19 AM
DRBuilder's Avatar
DRBuilder DRBuilder is offline
That is correct. Other than modifying the engine mount, the airframe is completely stock.
Dennis Roberts
Wake Forest, NC
EAA 1114, Apex, NC
N713DR Super-7 IO/540 SOLD
http://www.drrv7.com
Old 07-18-2012, 04:22 AM
DRBuilder's Avatar
Yes, it is slightly closer to the firewall but still allows you to remove the L Mag without removing the engine.... just barely though!
Dennis Roberts
Wake Forest, NC
EAA 1114, Apex, NC
Old 07-18-2012, 04:23 AM
pierre smith's Avatar
There really isn't much room for a shorter mount, Sig. On my -10, it's a close fit, so the -6 or -7 if not lengthened, would have to either be ballasted or have the battery shifted.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
