I had a O320 and took off a large 9 row Stewart Warner 10599R, which was really for a IO360 or even a 540. Hey I did not know. The RV-4 runs cool any way and this made it even cooler. Blocking air alone did not increase the oil temp enough.
I replaced it with a smaller 6/7 row cooler, I think it was Harrison P/N 8526250. That is the same as a SW Stewart Warner 8406R. I sold the plane, so I can't verify but fairly sure.
I kept the SW 10599R I removed and now using it on my RV-7 with a O360. If you are running a bigger hot setup, like a RV-8 with a IO360, suggest the SW #8432R. It is similar to the SW 10599R but is a double pass. Anyway you want hotter not cooler. SW is my number one choice for any cooler because they cool better and are better quality and design.
Van's sells CLONE coolers, like the "EA OIL COOLER 4211", which I assume is a Positech P20002C (*new part number*). This is a Harrison/SW clone I believe. The 4211 had problems and supposedly Positech made improvements and changed it to a P20002C part number. I would make sure you get the new improved model. Actually I would pass on Positech altogether and get a SW first or one of better brands of clone like Aero Classic or Niagara second.
Notice in Van's catalog also sells a Harrison/Stewart Warner "STYLE" cooler. Not sure what those brand those "STYLE" coolers are, but they are NOT Harrison or SW.
These are the equiv part numbers (to my best knowledge):
- SW #8406R
- Harris #8526250
- Aero Classic #8000075
- Niagara #20002A
- Positech #4211**
**(Note: new improved 4211 cooler part number 20002C, like the Niagara P/N to add confusion.)
I'd rather have an old SW or old Harrison rebuild/overhaul/cleaned than a clone, but that is me. You will end up still spending more than a new clone but cheaper then a new SW. If you don't have a critical cooling scenario like a RV-4 with a 320 than a clone I assume is fine.
Here is spruce's list of coolers :
http://www.aircraftspruce.com/menus/ep/oilcoolers.html
If you have cooler questions call Pacific, they know RV's and coolers and can point you in the right direction.
http://www.oilcoolers.com/
