Old 07-15-2012, 09:41 AM
mhflyit mhflyit is offline
Default Header tank AN fitting removal
Does anyone have suggestions on removing a AN fitting, that's been secured with resin, from the bottom of a header tank ?
Matt
Matt Hurley
Chino, CA
RV8 sold...'til next time!
Sonerai 2L 'Restoration'
www.ustool.com
www.hstooling.com
Old 07-16-2012, 12:18 PM
rv7charlie rv7charlie is offline
What kind of resin? If it's epoxy, alcohol will soften most older types. Heat will too, but that might not be an option. :-)
If it was applied to the threads, good luck.
Charlie
Old 07-16-2012, 12:44 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Heat......
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-18-2012, 09:38 PM
Its old - 25 yrs old. I'll try the alcohol first.
Thx.
Matt Hurley
Chino, CA
www.ustool.com
www.hstooling.com
