Update on this issue. I brought a wheel, tire, tube, tools, etc. home yesterday so I could take a closer look at this problem.
As it turns out, you need to keep the little nut and washer that attach to the base of the valve stem. The nut just sits in the circular cutout where the valve penetrates into the center of the wheel. I assume it acts as both a spacer and as an anti-rotation device to keep the tube from rotating on the wheel.
With the nut and washer in place, the geometry of the valve stem is correct and I'll be able to add air through the existing hole(s) in my wheelpant(s).
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
