Old 07-13-2012, 10:24 AM
tc1234c's Avatar
tc1234c tc1234c is offline
Default Engine valve video made using cheap dental cam
After reading Erich Weaver's report on cheap Chinese made dental cam I brought one and modified it. This morning after oil change I inserted the camera through lower spark plug holes and recorded video of valves. Since I held the camera in one hand and turned propeller using the other at times images were shaking. I don't have experience on engine thus can not tell if my valves are fine. If you see any problem please let me know.
Erich's report:
http://www.vansairforce.com/communit...ad.php?t=83011
My video:
http://youtu.be/Dq0H_yqSuGw
Ted Chang, VAF #681
2018 Due paid
Old 07-13-2012, 11:42 AM
YellowPeril's Avatar
YellowPeril YellowPeril is offline
I have to say...that's pretty cool...
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
Old 07-13-2012, 12:16 PM
erich weaver's Avatar
Way to go Ted!
The color pattern on your exhaust valves looks nice and symmetrical, which is what you want.
Which camera did you go with? I'm guessing you cut the camera case at the neck to make it smaller and used some heat shrink tubing to hold it together?
Erich
Old 07-13-2012, 12:20 PM
tc1234c's Avatar
Originally Posted by erich weaver View Post
Way to go Ted!
Erich
Erich,
I got ORC-03B that is the same as yours, I belive. Yes, I cut the case using a hand saw. It quite easy to do. I don't have big heat shrink so I just used tape. It works well. Thanks for sharing the information.
Ted
Ted Chang, VAF #681
2018 Due paid
Old 07-13-2012, 12:39 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Originally Posted by tc1234c View Post
Hey! How did you get that little tiny man into that little tiny hole? He sure is looking down his nose at the camera. Or maybe he is just "thumbing his nose" at the camera.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 07-13-2012, 01:11 PM
tc1234c's Avatar
I have auto plugs on top. If not, the tiny man would be able to get through the hole.
Ted Chang, VAF #681
2018 Due paid
Old 07-13-2012, 01:37 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Why were the valves replaced at 330 or something hours?
Old 07-13-2012, 01:43 PM
tc1234c's Avatar
My cylinders were on the ECi cylinder head rework SB list. They could not rework them so they sent me four new ones instead.
Ted Chang, VAF #681
2018 Due paid
Old 07-16-2012, 05:55 AM
novipilot novipilot is offline
Read some of Mike Busch's columns. He's a regular contributor to Sport Aviation. Also has a web site, SavvyAviator or something like that. I once read that if you have symmetry, which your valves look like, then you'll typically go another 100 hours without valve failure.
The video from this camera looks pretty good. Maybe we could get a group buy on the cams.
Rich Bond
Just a wishful observer
Gave up awaiting AOPA/EAA exemption request
2015 =VAF= Contributor
Old 07-16-2012, 08:10 AM
chaskuss chaskuss is offline
Erich,
I got OC-03B that is the same as yours, I believe. Yes, I cut the case using a hand saw. It quite easy to do. I don't have big heat shrink so I just used tape. It works well. Thanks for sharing the information.
Ted
Ted,
I just did a Google search on OC-03B dental camera and came up with nothing. I did find a listing for a ZD-03 [linked below].
http://factory.dhgate.com/dental-equ...p36909791.html
Could you please supply who manufactures this thing and perhaps a photo or link of it?
Charlie
