Old 07-12-2012, 10:53 AM
Default safety wire pliers choices
I searched the forum and found lots of posts about safety wiring, but nothing on what pliers to purchase. I have never done anything other than crude safety wiring on a boat motor. I have watched youtube videos and read how, so I think I understand how - but not what pliers to get.
there are some around $25 and some about $80. the $80 are reversible - is that a big deal? Is it worth the extra money? Thanks
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 07-12-2012, 11:11 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I have two pair, different sizes.
I prefer the smaller one, as I can get into tighter spaces with it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-12-2012, 11:23 AM
paul mosher
Posts: n/a
Default safety
Six inch non-reversable.
Old 07-12-2012, 11:40 AM
Sam Buchanan's Avatar
been here awhile
Expensive tools are nearly always very nice tools, but for occasional, non-professional use something like the following will work:
http://www.harborfreight.com/6-inch-...ter-45340.html
I've used the el cheap pliers for years and nothing has ever fallen off the planes.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 07-12-2012, 11:48 AM
Default Thanks
Thanks guys. Im all for saving $ when it is Ok to do. HB is great for some of the tools that are not used too often or do not need to be precision.
I have had good luck with their cheap 3" water pumps from China. Other than the threads on the hose connections not being anything available in the US, they work great. I have 2 Honda pumps - costing 4 times as much and 4 HF pumps. The Hondas are not even close to as easy to prime and start. I have had them in service for irrigation for 4 years with no problems at all. Start on first pull each year and run 4-6 hours a day. Not bad for $300.
rockwoodrv9a
Williamston MI
O-320 D2A
Old 07-12-2012, 01:14 PM
RV6_flyer's Avatar
I have the cheap ones and also a $100 Milbar that is reversible. After using the Milbar reversible ones, I highly recommend them over the CHEAP ones. The smaller of the two sizes is what I like.
You only get what you pay for.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 07-12-2012, 01:37 PM
Ditto on the Milbar, and get an older one if you can find one. I prefer the older version of the latching assembly.
Reversing is not necessary.
Dave
Old 07-12-2012, 02:02 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
I bought the Harbour Freight and, after a while threw them out and bought the Millbar (6" reversible).
I'm happy with the Millbar.
Old 07-12-2012, 02:20 PM
Ironflight's Avatar
VAF Moderator / Line Boy
We've got three pairs of pliers in our safety wire basket - two cheap ones I've had for years, and the more expensive reversibles (which Louise brought to the relationship). The only ones I grab now are the reversibles - the latch is easier to use, and it is nice to pick the correct direction for what you're doing.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-12-2012, 03:30 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I've got both the small and regular size ones from Harbor Freight.
The HF cheapies might get the job done, but there sure have been a lot of times that I've seriously wished I had a pair of nice 6" reversible ones.
Someday, I'll spring for some good ones.
EDIT: Just noticed that Avery has the 6" reversible on sale right now for $70. Rats! If only I wasn't pinching my pennies for Oshkosh right now.
Neal Howard
Airplaneless once again...
