Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 07-11-2012, 11:22 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Lightspeed Plasma III Six Cylinder Box Cooling?
Looking for some ideas on what folks are using set-up wise to cool the Lightspeed Plasma III boxes on 6 cylinder installs. Got a lot of ideas... what has worked best for others out there?
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 07-11-2012, 11:41 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Against the recommendations of the knowledgeable and intelligent staff at LSE, I have 1500 hours on a pair on the FW cabin side no cooling added.
As with all electronics cooler is better. There is a trade off of time and effort and $$.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 07-11-2012, 01:34 PM
Just to be clear... we are talking 6 cylinder installs only.
Reiley
VAF# 671
Friend of the RV-1
Old 07-11-2012, 01:55 PM
N427EF N427EF is offline
Default Fan
Since the Plasma III has a port for cooling air you might as well make use of it.
I installed one of these to the underside of the instrument area near the fresh air inlet. One hose is plugged into the LSI port and the other just blows air over the top.
2 pack of fans was $12.- and a little work to get the hose flange JB welded on.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 07-11-2012, 02:11 PM
I was told a blower is better than a fan... Kudos to my Genius friend!!!
Thanks for the input.
Reiley
VAF# 671
Friend of the RV-1
Old 07-11-2012, 02:16 PM
Where did you buy that little 12 volt blower?
Reiley
VAF# 671
Friend of the RV-1
Old 07-11-2012, 02:26 PM
pierre smith's Avatar
Default FW rear.
Like Kahuna, mine is mounted on the cabin side of the firewall...5 years and over 500 hours, no problems.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-11-2012, 03:04 PM
Local Electronics store "Fry's"
or this one.
http://www.amazon.com/Nidec-Gamma30-...entrifugal+fan
Ernst Freitag
Old 07-11-2012, 03:55 PM
Best,
And this was on a 6 clyinder Lycoming Lightspeed III install? Just looking correct for info...
Reiley
VAF# 671
Friend of the RV-1
Old 07-11-2012, 04:48 PM
rvmills's Avatar
rvmills rvmills is offline
Brother Darryl,
Kahuna is talking about his S8, and Pierre about his 10, so pretty sure both are Lyc 6s. In the FWIW category, on my Lyc 6 I also had my LSE Plasma I on the cabin side, and when I replaced it with an Electroair, the box went cold side as well. Both systems worked well with that install technique, with no supplemental cooling.
That little fan is kinda neat too...lots of possible uses for that!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
