Old 07-09-2012, 07:45 PM
Default Tips for building light
I'm. Of sure why he other thread was closed. It may happen here too. Anyway, two tips for how to build light ...
Battery - there are some new technologies for lighter batteries.
Wood prop - it was suggested if a Catto might be lighter than a wood prop. I can say that Craig just finished a "bolt on replacement" for my Aymur Demuth. The wood prop is a few pounds lighter that Craig's composite (not that I'm complaining).
Other tangible ways to stay light?
Old 07-09-2012, 08:12 PM
FresnoR's Avatar
FresnoR FresnoR is offline
Jog to and from the airport in a sweatsuit every time you build or fly.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 07-09-2012, 08:21 PM
Ironflight's Avatar
VAF Moderator / Line Boy
No wheel pants or fairings. Lighter tires (fewer plies). One Comm radio, remote very lightweight transponder (the Trig weighs almost nothing). Fuses only - no breakers or VP system. SD-8 alternator? That would save a few pounds for sure!
How about leaving the wingtips off and just closing them with flat aluminum plates? Fibergalss isn't all that light. Oh - isn't the taildragger lighter than the tricycle? You could put a lightweight DJM tailwheel on it and save another 14 ounces....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-09-2012, 08:29 PM
Snowflake's Avatar
I'd still like to see the path to an 888 lb empty weight for a -6.
Single Skyview (or GRT, etc) with both flight and EMS info.
Remote transponder and com, controlled via Skyview.
Lightweight interior.
Wood prop.
No paint.
Tailwheel.
Slider vs. tip-up - Any weight savings there?
Lightweight starter.
Lightweight Li-ion battery.
No carpeting or interior panels.
Lightweight foam/fabric seat cushions.
That's all I can think of!
Rob Prior
Old 07-09-2012, 08:33 PM
N941WR's Avatar
N941WR N941WR is offline
Check out this thread on tips for building light.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-09-2012, 08:44 PM
Wood prop.
No paint.
Tailwheel.
I've looked at mine time and time again with the idea of cutting weight. It weighs 1031 pounds with a light prop and engine, a PC 680 battery, and a lightweight alternator. I'd guess there are 40 pounds of paint, primer, and filler in the airplane. That weight could have been saved. I could get rid of 9 pounds if I swapped starters, 5 pounds if I took out the carpet, and probably 5 pounds of stuff in the panel if I switched to glass. After that, I could save another 10 pounds by eliminating all external lights. So let's say all of that stuff is 70 lbs. If I eliminated all of it, the airplane would weigh 960 lbs, or thereabouts. That's roughly Van's factory weight claim for an RV-6.
At that point, what is left is the opportunity for a lighter (than 13 lb) battery, a composite sump, and eliminating the comm radio, transponder, and intercom. Beyond that, you have to start leaving airframe components (wheel pants, wingtips, etc) behind to save more weight.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-09-2012, 09:21 PM
bkthomps bkthomps is offline
stop going out for $100 hamburgers and pancake breakfasts
Old 07-09-2012, 09:34 PM
dealfair dealfair is offline
Yep, the engine & my fat keester are the heaviest loads in mine.
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
Old 07-10-2012, 05:22 AM
Using some of the new glass instruments will make a difference. When it comes available, I'll be removing my DFC-250 AP head unit, electric DG and electric Horizon - replacing with a Gemini AP. This will remove about 8+ lbs.
... or ...
going the next step and removing (almost) all of the individual engine instruments for an engine monitor. This might remove an additional 4+ lbs.
When my battery gives out, I'll be checking in with rocketbob to get his opinion on the new LiFePO4 (or similar) batteries.
Old 07-10-2012, 10:19 AM
panhandler1956's Avatar
Talking
If you are building an -8:
Grove aluminum gear
For everyone else and RV-8s:
NO PAINT!
Also skip the extra electrical system/backup battery. Most new glass has internal batteries to keep things powered. Unless you are running electronic ignition.
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
