Old 07-07-2012, 11:36 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Finding a superceding Service Instruction
I am trying to figure out how to determine what Service Intruction has been released to supercede an old one at Lycoming. Specifically I was trying to find Service Instruction 1129A (Accessory Drive Belt Tension) and it is not listed in the Service Instruction library (http://www.lycoming.textron.com/supp...ons/index.html). There is not another one with a similar name, so how does one find a newer one that replaced this one?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-08-2012, 09:41 AM
chaskuss chaskuss is offline
Mark,
You can find what service publications are still valid and what the most current revision of that document is [SI 1129B in your case] in SSP 210 SERVICE BULLETINS, INSTRUCTIONS AND LETTERS INDEX. [SSP stands for Supplemental Service Publications] This document allows you to look up a document alphabetically, numerically or by engine model. The PDF search feature is very handy.
I will email you a copy of SI 1129B & SSP 210
Charlie
PS To check on what the latest revision of any Operators Manual, Overhaul Manual or Parts Catalog is, refer to SL L114AU, available at
http://www.lycoming.textron.com/supp...fs/SL114AU.pdf
and it's supplement
http://www.lycoming.textron.com/supp...L114AU-S-1.pdf
Last edited by chaskuss : 07-08-2012 at 11:26 AM. Reason: Corrected SL L114AT to SL L114AU and added link to Supplement 1
Old 07-08-2012, 09:49 AM
Thanks, just weird that the 1129 (A or B) isn't listed on the Lycoming site.
RV-10
N928MT
Build Project Site
Old 07-08-2012, 10:15 AM
Mark,
Lycoming does not post ALL their tech documents online. Mostly, they post documents which are new, popular or recently updated. SI 1129 was last updated in May of 2000. Please check your PMs.
Charlie
Old 07-08-2012, 11:37 AM
Mark,
My bad. I see that SSP 112 has superceded SSP 210 [as of April 2012]
Charlie
Last edited by chaskuss : 07-08-2012 at 11:38 AM. Reason: corrected month of release of SSP 112
