Main Wing Spar Match drill Question
Has anyone had any experience mating a wing main spar with a NON-match drilled carry through spar?
Reason for my question is that I am nearing completion of my wings and I may have an opportunity to purchase a nearly completed fuse.
I wonder if the NC drilled holes are close enough to allow the mix and match situation?
This is for an RV 9-a but I suspect experience with any of the later model planes would be similar.
-Mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
