Old 07-06-2012, 04:15 PM
Aircraft Specialty Aircraft Specialty is offline
Default Flap Toggle Switch Question
A quick survey question from the skunkworks department at Aircraft Specialty......
Can you please let me know if your DPDT toggle switches used to activate the flaps will rotate when turned, or if they are solid.
Thanks again,
Steve
Old 07-06-2012, 05:46 PM
larrynew's Avatar
larrynew larrynew is offline
As received from Van's, the flap switch does not rotate inside the housing when turned.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 07-07-2012, 02:18 PM
PaulR PaulR is offline
I made some neat flap levers similar to the ones in "Brand X" and gave some away. It seems if you used Van's switch they were fine, but the ones from B&C rotated and made the lever kind of useless.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 07-07-2012, 04:43 PM
Fearless's Avatar
Fearless Fearless is offline
The ones sold by B&C should have come with anti-rotation ring. The Aero Connection book shows the distance from center to drill for tab on the anti-rotation ring in the switch section of the book.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 07-07-2012, 06:23 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I think he means the bat handle itself being able to spin freely inside the switch, not that the switch body is turning in its mounting hole in the panel. Some toggle switches are made so there's no "axle pin" thru the handle, but rather just a ball joint, so the handle can spin. I haven't typically seen this design on the large heavy-duty switches commonly used for flap switches, but have seen it on lots of miniature toggle switches that have rounded "bat handles".
Neal Howard
Airplaneless once again...
Old 07-07-2012, 10:19 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default No Rotation
I use a Honeywell 2TL28-7 for my flap switch. The toggle lever is threaded 8-32 (and doesn't rotate) so you can screw on whatever type handle you wish. It comes with a Delrin handle that's about 5/8" wide.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
