Old 12-09-2019, 02:11 PM
GeoffP's Avatar
GeoffP GeoffP is offline
Default Pre-dimpled nutplates
I've bought dimpled nutplates, in the same sizes that Van's use in many applications. It gives me a choice, and if my memory serves me correctly it's the same part number with a "K" at the end.
RV-9, Tail Feathers done, Wings almost done.
Old 12-09-2019, 03:05 PM
Sue Sue is offline
Default Dimpled nutplates
The glaring question I have to ask is
why not just get dimpled nutplates?
Old 12-09-2019, 03:22 PM
rocketman1988 rocketman1988 is offline
Default Nut plate
I am really not sure why this is even an issue; it takes like five seconds to dimple the mounting ears on a nut plate with a hand squeezer.
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 12-09-2019, 03:25 PM
BillL BillL is offline
Default Agree . . .
Or just use NAS rivets. A flush head can install a nut plate in .025 material just fine. And much less time investment in the entire process.
Bill
RV-7
Lord Kelvin:
Old 12-09-2019, 05:23 PM
IIRC the part number with the K suffix is manufactured to accept a dimple nested into the center hole - the threaded one - for use with flat head screws. The discussion here concerns dimpled ?ears?, the ones usually riveted on.
Old 12-09-2019, 05:29 PM
bcondrey bcondrey is offline
There are dimpled nutplates available from Van?s, they are supplied in the RV-12 kits. They have a ?D? suffix (i.e. K1000-08D). Not sure what additional sizes are available, as others have said, pretty quick to just dimple standard nutplates or use NAS rivets.
Bob
RV-10 builder x2
RV-7A under construction
EAA Tech Counselor
Old 12-09-2019, 06:21 PM
GeoffP's Avatar
The part number for some of the ones I bought were MS21047L06K, and these certainly had the dimpled ears for countersunk rivets. The part description is "6-32 THREAD, SELF-LOCKING NUTPLATE, TWO LUG, LOW HEIGHT, CADMIUM PLATED CARBON STEEL, 450 DEG F, WITH DRY-FILM LUBE, COUNTERSUNK RIVET HOLES
ALT. PART NUMBER: NAS680A06K"
Old 12-09-2019, 07:02 PM
Girraf Girraf is offline
A seasoned builder saw a dimpled nutplate on my project and asked why in the world I would do that. Told me about NAS1097 rivets. I started using them and never looked back.
RV-7:
Empennage complete!
Wings in progress
Old 12-10-2019, 07:11 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
Dang, looks like the RV-12 skin is only ~0.018, at least the piece I measured, which was the rudder. Steps away... Ok, got about 0.023 on the VS where the 18 nutplates were, not sure if that is 0.025 nominal?
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer
RV-12is Empennage Kit, Fuse Kit, #121228
N781PT Reserved
Donated 2020
Old 12-10-2019, 04:09 PM
Yes .025 as stamped on the sheets. It may work for thinner, you should try it before committing to its use.
I like the NAS as you can just countersink with the deburring tool. I do 7 rounds and it is done. YMMV as always.
Bill
RV-7
Lord Kelvin:
