Old 06-26-2006, 08:17 PM
cstanley cstanley is offline
Default Have I Been Burned on a Rivet Squeezer?
I bought an old but operable Chicago Pneumatic rivet squeezer on e-bay. Now that it is in, the dies that go with it appear to be too big. I can change the yoke no problem. The question is whether I can change the piston. Is it possible to buy a new piston that is the correct size to fit through the smaller yoke openings for the appropriate dies, or do I chalk this one up to a learing experince?
Old 06-26-2006, 08:50 PM
ptrotter ptrotter is offline
Give Fred at Clear Air Tools ((888) 777-1650) a call. He is the most knowlegable person on squeezers that I've found.
Paul Trotter
Sussex, NJ
RV-8 82080 Finish/FWF Kit
N801PT
Old 06-26-2006, 08:53 PM
RScott RScott is offline
Call or email Fred Kunkel at Clear Air Tools: contact@clearairtools.com
(888) 777-1650.
He knows about these things & overhauls them.
However, offhand, it sounds like your dies are the wrong size. Is the squeezer a CP 214? If so, you have the right squeezer & the wrong dies.
Old 06-26-2006, 09:26 PM
G-force's Avatar
G-force G-force is offline
Sounds like you got one with 1/4" holes instead of the more common 3/16". You should just be able to replace the yoke and the piston. I think the set holder (piston that goes through the yoke) can be replaced with an adjustable one (with the 3/16" hole) for about $65 from Avery, Brown, etc.
As for you old yoke, have the hole welded up and with a bit of machining or grinding, you got youself a "no hole" yoke for those tight spaces!
