Follow up/ solution
Guys-
Thanks for your input. After having an electronics guru neighbor come over and pop the thing out in 10 seconds, and speaking with Marc at VP, here is what to do:
1. Try rounding the head of the tool to a more bullet shape. After inserting, maintain tension on the wire while wiggling the pin side to side. Per the manual, not too much lateral force but a bit of wiggling does the trick. I wrapped a band of duct tape around the middle of the tool to use as a handle.
2. Marc suggested if all else fails to remove the white face by slipping a narrow flat tool into the two slots on the short side of the facing. By pushing out, you should be able to remove the white face without damaging the unit (this goes against the manual instructions, but Mark said it is OK as long as you don't break the plastic. He stressed you need to be pretty careful doing this.) Then you can remove the terminal manually.
Marc at VP was very helpful and took the time to patiently answer some of my other VP-X questions. Other than this snafu, I am very satisfied with the VP-X so far as well as excellent customer service.
Eric
Eric Stewart
=VAF= dues paid 2016
facebook.com/TheSR1Project
Reason: spelling
