Old 07-04-2012, 02:10 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Oil Sump Plug Torque?
Anyone know what the oil sump plug is classified as so that I can refer to the lycoming service table of limits to determine what they should be torqued to? Is it just a pipe plug class?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-04-2012, 08:04 AM
Walt's Avatar
Walt Walt is offline
From the Lyc OH manual:
Install all crush type gaskets except the self centering
type, with the unbroken surface against the flange of
the plug or part being tightened against the seal. Turn
the part until the sealing surfaces are in contact and
then tighten to the angle of turn listed for the
appropriate thread size.
Plug is an 18 pitch which calls for 135 deg for the copper/asbetos gasket.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-04-2012, 08:51 AM
aerhed aerhed is offline
Wrong plug Walt. Charlie, yes it is just a pipe plug.
Actual repeat offender.
Old 07-04-2012, 09:12 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Washer
Anyone have the ACS part number for the gasket / washer for the large bolt that secures the oil finger screen at the bottom rear of an O-360?
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 07-04-2012, 09:27 AM
Walt's Avatar
AN900-16
This is the washer for the plug "I thought" he was talking about above.
Old 07-04-2012, 09:57 AM
Thanks. The oil pick up screen is my next inspection. Does the YIO-540 use the same size crush gasket for that AN900-16?
RV-10
N928MT
Build Project Site
Old 07-04-2012, 09:59 AM
ccsmith51's Avatar
Originally Posted by Walt View Post
AN900-16
Thanks Walt.
Chris Smith
