Old 07-03-2012, 07:50 PM
tomhanaway tomhanaway is offline
Default avipak strobes not firing during flight
Just did my first night flight after completing phase 1.
I have an Avipak box firing wing and tail strobes. If it's just on battery power on the ground, all strobes work fine.
Once flying, the strobes stopped firing. If I switched them off and on, I could see the wing tips flashing for one or two sequences, then nothing.
When I returned to ground and shut down engine, the strobes were working fine again.
My guess is it's somehow connected to alternator output, which would increase at cruise power. However, no issues with any other electronics.
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
Old 07-03-2012, 08:01 PM
fl-mike's Avatar
fl-mike fl-mike is offline
check the power supply ground wire. Might be loose.
Mike W
Venice, FL
N164WM
