Brake line compression fittings question
I'm using the plastic brake lines that Van's provided for a different purpose (vent line for smoke system, actually) and have a question...
The parts that came with the kit included a bunch of 90 degree fittings that have the compression fittings on one side and NPT on the other...does anyone know *what* these fittings are properly called, and if there's a fitting that is this somewhat unique compression fitting on one end with a flared fitting on the other, or at the very least, compression on one end with an NPT on the other, but *straight*, not 90 degrees?
If I even had the name of the type of fitting these are, I could probably search for what I need, but I don't know what to call them...they seem pretty unique, but maybe it's just me because I'm not using them for anything on the plane...
TIA, as always...
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
