If you engaged the starter for just a bit, but not long enough to start, the starter pinion may stay engaged in the starter ring.
Get the airplane to where you can safely start it. Start the engine and then shut down. The pinion should have retracted. If not, don't run the engine that way.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
