I've pulled the prop and flywheel in that situation. That works, although is a PITA, especially if you have a CS prop.
A thought is to pull the top plugs and give the prop a mighty "hand propping" heave. Might work. Might not...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
