06-30-2012, 04:02 PM
Tie Downs at OSH!
Can you rent Tie downs for a week in the experimental parking section at OSH? We have limited space in the RV12 and wish to lighten the load every chance we get. Couldn't find the info on the Airventure web site. Thanks for you help!
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
06-30-2012, 04:04 PM
Must bring your own.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
06-30-2012, 04:32 PM
No not true, there are volunteers that drive around with tiedowns you can rent.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
06-30-2012, 05:11 PM
Moderator/Tech Counselor
We used to have them at the Showplane registration on the flightline, but that building is no longer there. Maybe Jeff Point can chime in about that. I'm sure they have relocated those tiedowns, but where, I don't know.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
06-30-2012, 05:28 PM
You can rent tie downs at homebuilders HQ when you register, but I would not recommend it. I would not trust my pride and joy to the cheap tie-downs/ ropes that are provided. You can make a set of EAA tie-downs (not the kind they rent) and they are not all that bulky or heavy.
http://www.airventure.org/planning/tying_down.html
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
06-30-2012, 06:02 PM
If you fly in when the grounds are open you can buy some from the vendors there. Try AFS in the hangars or there were some in the flymart area.
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
06-30-2012, 06:55 PM
rent or own
EAA chapter 444 makes tie downs and sells them in the north forty. We used them for years with the jabirus and lightnings. They work great in the hard soil in Oshkosh. You can get them from their building just north and west of the war bird area. I think it is thirty dollars and if you return them you get ten dollars back. They will even let you borrow a big hammer to drive them into the hard ground( if it is dry ground you are gonna need it)
Ben
RV-8,, Tail half done and in storage for now..
2014 Donation made for too many reasons to count.
07-01-2012, 06:18 AM
I made a set of those EAA tiedowns and they are really nice. They hold like crazy.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Glen L Torpedo
07-01-2012, 08:18 AM
Tie Downs
Tie down rings, stakes, and ropes should be essential equipment IN every plane, just like pitot tube cover and mini chocks. If you make an unscheduled stop at some airport along the way with an incoming storm, you would want to tie down!! Many airports do not have tie down spots or if they do they don't have ropes/chains. And don't buy/bring those twurly dog chain screw in type stakes, they often cannot be screwed into dry hard packed ground and sometimes breakoff, leaving an exposed sharp stake for others to taxi over.
Stu McCurdy (Falcon)
RV-8, 78TX, Flying
Formation Flying, Inc (FFI)
Falcon Flight
