Old 06-29-2012, 09:38 PM
jdeas's Avatar
jdeas jdeas is offline
Default Traditional Ingition Harness
Does anyone have experience with Skytronics Aero-Lite harness? Any suggested alternatives using Slick mags and 3/4" plugs?
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 06-29-2012, 09:41 PM
aerhed aerhed is offline
If you mean the one with the blue silicone wire jacket, I can tell you that the jacket can rip.
Actual repeat offender.
Old 07-01-2012, 11:06 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Skytronics
Yes I have used them when the standard Slick by Champion harness was unavailable. In my opinion they (Skytronics) are an inferior product. The did not fit the application quite as well, and the outer jacket is very thin and easy to damage. I would recomend for a traditional ignition harness the Slick by Champion harness for your application. Most applications are listed in Slick Harness Brochure JP00752A. Good luck, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
