06-29-2012, 11:57 AM
Oil Temperature..another question
I am trying to confirm the temperature readings on my 200 HP lyc. I think that the oil temp probe reads temp of the oil coming out of the cooler, therefore when the engine is operating at normal temp, with the vernatherm closed and oil flowing thru the cooler, I'm reading that temperature and not the oil temp going into the cooler.
Is this correct.
thx
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
 I just wish I could afford to live the way I do
Reason: Changed word
06-29-2012, 01:52 PM
The vernatherm CLOSES at high temp. That's why bad seating yields high oil temp.
Actual repeat offender.
06-29-2012, 03:03 PM
Oil
Jerry:
Did you check the seat in the crankcase when you changed the thermastatic valve (verrnratherm) ?
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
06-29-2012, 03:49 PM
Checked
Mannan
I put a new oil filter adapter on when I put the new vernartherm in just to make sure.
New vernartherm, new high effiency cooler from Pacific coolers, new hoses, checked sending unit, new baffle seals, new sceet tubing to smooth air flow and crossed fingers and toes. All to no avail.
Just ordered a 13 row cooler and 4 inch tubing and mounts.
If the new bigger cooler doesn't work I'm gong to make it a glider, or an anchor!
Anybody have the answer to the question in OP.
VAF #818
06-29-2012, 04:51 PM
Is this correct.
thx
Yes. The oil temp probe reads the temperature of the oil going into the engine, whether or not the cooler or oil filter are being bypassed.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
