Old 06-29-2012, 07:53 AM
noelf noelf is offline
Default Question for the DAR's
I have been flying my unpainted RV-6A for two years now, and am thinking about painting it. My FAA required data plate is riveted on the airframe. Is it legal for me to remove the data plate so that I can paint under the plate? After paint, the plane would not be flown until the data plate is reattached.
Thanks.
Noel
RV-6A N6NF
tip-up
flying
Old 06-29-2012, 08:08 AM
Vern's Avatar
Vern Vern is offline
Default Dataplate
Yes. You can remove it for painting.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 06-29-2012, 09:39 AM
jjconstant's Avatar
jjconstant jjconstant is offline
Yup...that's what my painter did.
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
Old 06-29-2012, 06:03 PM
Mel's Avatar
Mel Mel is offline
Yes, as long as it is permanently re-attached before flying.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-30-2012, 04:27 AM
Thanks to all.
And yes, it will be permanently attached after paint.
Noel
RV-6A N6NF
tip-up
flying
Old 06-30-2012, 07:38 AM
PaulR PaulR is offline
Default Permanently Attached
Does that mean that one should use SS pop rivets in the SS data plate or will AL pop rivets suffice. Seems like AL will work fine since the underlying structure is AL. I've had a hard time finding any 3/32 or 1/8 SS pop rivets without buying a large amount.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 06-30-2012, 07:51 AM
Mel's Avatar
Mel Mel is offline
Aluminum pulled rivets are fine. Just be sure that the data plate itself is not aluminum.
