Old 06-27-2012, 08:15 PM
868RM 868RM is offline
Default Wing bolts
Does anyone know if liquid nitrogen is too cold for shrinking the wing bolts. I am concerned about messing up the heat treat properties. Thanks Ron
Old 06-27-2012, 08:35 PM
FLTENG FLTENG is offline
I found that dry ice worked very well.
Old 06-27-2012, 09:55 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
I really don't think you need it, and I'm not sure it would really help all that much anyway given the relatively minuscule reduction in diameter it would offer. A brass set for your rivet gun (low-to-moderate air pressure) combined with some light grease is all you really need to tap the interference fit bolts home.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 06-27-2012, 10:37 PM
Bavafa Bavafa is offline
I used dry ice in alcohol and it helped tremendously. The bolt went in with a lite tab on them and shortly later it started tightening up just in time to get the nut on it.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 06-28-2012, 05:13 AM
Default dry ice
Thanks I will try to find some dry ice. There is plenty of liquid nitrogen around but not much dry ice. I will look some more.
Old 06-28-2012, 05:33 AM
LAMPSguy's Avatar
LAMPSguy LAMPSguy is offline
Default Dry Ice
Try at your largest local grocery store. Dry ice is often available in the front near the checkout counters.
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
Old 06-28-2012, 05:35 AM
RV6AussieNick RV6AussieNick is offline
Default Liquid nitrogen
If you have liquid nitrogen handy i'd use that, it's a lot colder, just don't burn yourself.
Like the other guy said you probably wont need it, either grease or sealant (pro seal) will work well when tapping the bolts in.
One negative with cooling parts is, as they normalise in temp they attract condensation, that can lead to corrosion later on, that is why sealant is a good idea.
Use a wood or brass drift so you don't mar the cad plating finish.
Good luck with what ever you decide..
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
Old 06-28-2012, 07:28 AM
krw5927 krw5927 is offline
Can't mess up heat treat properties by getting too cold. Once the bolt gets back to room temp the properties are exactly the same as before.
There's probably a point where the bolt would become more brittle and whacking on it with a hammer may not be wise, but I doubt that would be at liquid N2 temps.
Kurt W.
RV9A
FLYING!!!
Old 06-28-2012, 01:27 PM
longranger's Avatar
Originally Posted by krw5927 View Post
...There's probably a point where the bolt would become more brittle and whacking on it with a hammer may not be wise, but I doubt that would be at liquid N2 temps.
I'm a bit skeptical about the last (blue) part of this statement. I'm only a lowly intrumentation engineer, and I know nothing of the metallurgy of Van's wing bolts (other than assuming they are some alloy of high-strength carbon steel) but in several decades of working around liquid rocket test stands I've never seen anything intended to be exposed to cryogenic temperatures (-150F or below) made of carbon steel, due to the loss of ductility at those temperatures. Even with stainless, only certain alloys are used. I know there have been cases of car/truck frames failing in the range of -50 to -100F.
Probably a moot point though, as the bolt at -320F (boiling point of nitrogen) the bolt probably wouldn't require a hammer...
RV-7 TU 904KM (reserved)
Construction Log
Old 06-28-2012, 02:00 PM
DanBaier's Avatar
DanBaier DanBaier is online now
Just a little Boelube on bolts that had been kept in the freezer worked for me.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
